Hi guya, I have had this up before, but I still got alot knock problems. I have soon tryed every things, and I dont know what to do now.
I have replaced the ignitions leads and rotor and distrubitor cab and spark plugs and so on!
I have testet the fuel pressure and thats ok, 3.2 bar on full boost! I have tryed severel timing settings. Betvine 19 - 9.5 degress TDC and 16 - 5.5 degress TDC.
I have a 900 from 1990, lucas full pressure turbo 16. Running with mbc/bleeder valve and 3" down pipe and mats fuel chip and 9000 intercooler and blow off valve and KN air filter. The boost is about 1.1 bar!
I have looked at the timings marks and they are ok! I replaced the chain tensioner because the chain was a bit loose. That did not help! I am running with octane 98 fuel!
I cant hear the knock, but I can see it on the led!
I am planing to try another knock and another AMM. First I will try adjust my AMM for somthing.
Can it be the cat maybe? Or the O2 sensor, have hears that the O2 sensor is not the same as bosch.
What can it else be?
