After having a lot of problems recently with my good ol' clutch cable, I decided to install a Viggen clutch and the hydraulic conversion kit from Taliaferro Saab, and do all the work with the help of a friend and the occasional advice (and tool) from my dad. Since others have posted about installing clutches, I'll just post about the surprises I've found so far, and how the hydraulic kit is going.
I had no luck finding one of the engine support beams shown in the Saab service manual and the Haynes manual. I made one myself out of a 2"x4" and a 1" threaded eyelet from Home Depot. Total parts cost: $5.00.
The ball joints wouldn't come out with the usual tuning fork-looking ball joint remover. It just split both boots open. Replacements are $25 each at the dealer. I had to disassemble the entire lower suspension, pop the driveshafts out of the hubs, and use a small gear puller to pop them loose.
To get the bearing bracket out for the intermediate driveshaft, the alternator has to be tilted out of the way. The top bolt was so tight that it couldn't pivot, and it was very hard to get to, but I did it with an 8mm hex socket and a 1/4" ratchet with a short jack handle slipped over the end for leverage.
My throwout bearing looked pretty fried after 63,000 miles. There was no grease left on the shaft, so it was hard to slide, and it sounded really dry when spinning it. The clutch plate had a little bit of life left in it, but not much.
As for the hydraulic clutch kit, installing the pedal involves drilling three holes in the firewall. This was really easy with a couple of hole saws and a 3/8" drill bit. The template on Taliaferro Saab's website was a little small, but printing it at 113% was perfect. Other than the pedal installation, the rest should be extremely easy. The slave cylinder mounts in the transmission with three screws and the hoses all snap together. The brake fluid reservoir already has a nipple on the bottom for the clutch cylinder hose, but I will need to punch a hole in it since it's sealed up.
That's where I'm at now, but I'll be sure to let you guys know how the clutch works when it's all finished next weekend!
