Maybe ball joint?
Only shakes at 40-60mph on mild turns and getting worse. I didn't notice anything loose when up on jacks for 4 wheel brakes but that was before it got bad.
Should I be able to tell if I just jack up that wheel? Do I need to try to pry anything? Do I need to put both wheels up in air?
Sounds like it could be the axle, yes. If it only shakes when you leg into it that usually the axle. I grab the axle shafts and shake them with the car lifted up, replace the one with the most play first.
My wheels used to shake going into turns before I got new shocks.
If there where bumps it would sometimes run wide.
Also check the tie rod ends, inner and outer.
