Appreciate that, Ill be tackling it tomorrow, along with some new spark plugs.
Thanks
How to change the sensor on the 98-01 SportCombi model
I changed my left-middle sensor today and thought I might post some pictures on how to change the sensor on the earlier model of the 9-5 SportCombi (98-01).
1. Apply pressure on the sensor itself. It will give at approx 10kg pressure and revert back into the bumper.
2. There are three clips that you loosen with a screw driver.
3. At the same time you use a screw driver to pull put the housing for the sensor, then the sensor itself.
//Wasseng
TechII error codes
BTW - The Tech II registered three error codes (i Swedish) before I changed the sensor.
B2926 (1) - Vänster mittre avståndsgivare. Kommunikationsledning kortsluten till B+
B2927 (6) - Vänster mittre avståndsgivare. Kommunikationsledning avbrott/kortsluten till jord
B2929 (8) - Vänster mittre avståndsgivare. Internt fel.
//Wasseng
