41 - 43 of 43 Posts
Thanks, Les. I see what you are saying. So you can trace the circuit but not get to repair. I thought that you had found a way thorough the epoxy.
How do you get through from the metal side? Are you cutting the upper half off so that you get access inside?
Did Les68 ever post the schematic and does anyone have one for the T7 DIC? When I get some time I'm going to try to cut around the base of the DIC on the bottom side, chisel around the coils to see if I can separate the base with the attached board from the potting mix to get a good look at what we're dealing with. Not sure this will help towards a rebuild solution, but maybe someone can make the leap out of the box and design a DIY replacement from the ground up. It'd be great if we don;t have to scrounge the internet for NOS or trust DICs from unproven manufacturers.
41 - 43 of 43 Posts
