My 2nd BPC valve just failed, it was off a 97 9000CD LPT.
Now I am back to base boost.!!
It is an electrical fault, the ohm reading on one pin is .4 ohm instead of 3 ohms.
Has anyone opened one up and repaired it.
I am wondering what I would need to do, not easy since it is a sealed unit.
Thanks for reading
Are you saying the mosfets can kill the BPC valve. From what I read I thought faulty mosfets would blow fuse 5.
If it was mosfets that were dodgy then I would have faulty ones in 2 ECUs. The ECU I am using is a spare, and my original is untouched, except for the pins.
Will check your link and see if it is the same one I have.
Aha - yes it is, I should have read it again.
However I also want to know if anyone has repaired the BPC valves.
take this opertunity to use the t7 apc,
these need to be programmed with the ecu to be able to work but...
im sure you can do it, as you have now seemed to of sussed out the t5 suite programme :D (beyond me)
i,ll back this up - not a better valve but a much cheaper, more reliable one
the soldering on the ECU is the only fiddle bit
