Is it as simple as connecting the brake line and doing a gravity drip?
I don't have a pump to connect to the system.
Yep, just keep the reservoir full and gravity will do most of the work. Bleed all 4 calipers when you're done. Air from the one opened line and caliper can make it's way to the other corners of the car.
If possible, use a brake hose clamp to keep most of the fluid in the lines and let in the least amount of air.
EZ bleeders make the job a whole lot easier, faster and truly a 1 man operation.
Thanks, yeah I'm going to get a pump for next time. That took forever to bleed the new rears and then continue with the full flush on the fronts.
