How can I best run a wire from the floor console to the top of the dash close to where the AC sun sensor is located?
I am asking as I recently installed a Parrot CK3300 handsfree kit. This kit is different from other Parrot kits in that it has a built-in GPS, and towards that small GPS-antenna which is attached to the main Parrrot unit with a wire.
I first installed this antenna right between the keyhole and the gear stick as I could easily run the wire to there. However, I am getting really bad GPS coverage from this position. I would like to move the antenna to a better location for example close to the top-side of the dash close to where the AC sun sensor is located. That position seems to have the best line of sight towards the sky.
Thanks, Michael
Thanks, Michael
