ok so i took the rubber elbow off connected beetween the TB and the plastic pipe, it was full of oil. guessing thats a bad turbo / seal ?.. turbo looks like its up front behind the radiator. how hard are they usually to pull off and replace?
Its a little bit of a job. but not too hard.
Any CEL?
before you replace anything you will need to isolate the problem, turbo, head etc.
A compression check would be in order,
how is the turbo gauge acting? is it showing boost?
And Welcome to the site.
