1 - 20 of 30 Posts
1999 OG 9-3 'vert
Hi,
I just recently set up a spare laptop with GlobalTIS but how can I check if I have security access. I have OG 9-3 and 06' 9-5. I know those two don't need security access, but is there a way to check? Is there a change or anything on those two cars that would require me to get security access?
You do not need security access for your cars.
TECH2 will tell when you need security access and it will explain what to do.
1999 OG 9-3 'vert
I know that, which is the key of this question. How do I check if I can get security access (if I installed GlobalTIS right). Is there a way to check since I have cars that dont need security access?
First you select which module you want to change or reprogram it.
Than you start to reprogram module. If this needs security access, TECH2 will tell it. Then follow what TECH2 tells.
You can not "precheck" this.
1999 OG 9-3 'vert
Which module on those cars needs security access? How do I get to that point on my 2 cars I listed?
If the Tech II talks to the computer, you probably have security access. Most of the problems seem to involve getting the two to talk to each other. Trying an SPS update of whatever your car might allow updates (ACC would be a safe bet) is one way to check communications.
1999 OG 9-3 'vert
Ok I will try sps or acc...I tried getting security access w/o the car and it said it was successful so maybe that's a good sign. I will be able to try it on a newer 9-3 on Monday and know for sure I guess.
Nope. Security access needs to ask first with TECH2. You can not get security access accidentally.
Security access is specific to the car you are working on. You need to connect to the car, request security access, then connect back to the PC to so it can generate the keys, and then you connect back to the car. It's only good for the VIN number you're currently working on and it will be lost when you shut off the Tech2 or close Tech2Win.
My experience is that all of this software is full of bugs--I would not be surprised at all if it claimed you had security access even if you ran it without first connecting to the car.
1999 OG 9-3 'vert
Discussion Starter · #11 ·
Thanks for explaining but I know how it works, my question was/is can I check if I have security access w/o the actual car, that's all. I guess answer is no but I thought there has to be a way to double check the system or something similar.
So this is my point, it is impossible to have security access to a car you don't have.
1999 OG 9-3 'vert
Discussion Starter · #14 ·
I thought maybe there is a way but I guess not.
Ok, I just installed new CIM in the car but I cant turn the (matching) key in the ignition at all. Is it a bad ignition switch?
I assume this is an NG9-3.
The CIM would either have to be brand-new, or come with a matching key.
WIS says that a brand new CIM can use a key that was used on another CIM. Mimmi disagrees. I have never tried this.
In any case, you need to program the new CIM to the car. And yes, Tech II will ask for security access which you will have to grant using the software on the laptop. And once you have security access, you can program the CIM and the fob(s).
New CIM can use old fobs that are from THIS CAR ONLY. Fobs needs to be stored to ECU. I have never tried this, but I have done several.
You need TECH2, CANdi and security access.
1999 OG 9-3 'vert
Discussion Starter · #17 ·
Thanks EdT, but don't I need to turn the key to on position in order for car (ECU) to talk to the tech 2?
I thought I turn the key, access the car with tech 2, car ask for access and than I go to the laptop.
TECH2 will tell how-to if you can not turn fob.
1 - 20 of 30 Posts
