You need to consult a doctor.:roll:DrSandman said:I give the brand another 10 years, tops. Then we will all be in possession of orphans. Your thoughts?
And moderator, would you mind leaving this question in this forum?
Dr. Sandman, I think you've been sleeping. :lol:DrSandman said:I give the brand another 10 years, tops. Then we will all be in possession of orphans. Your thoughts?
It's Volvo that has made cars in the Netherlands. Valmet in Finland built the original 900 convertible and later some regular 900s. I once owned a 1990 900 built in Finland! The NG900 and OG9-3 were also made there, but I think just the convertible. Most cars were made in Sweden. Arlov, near Malmo, was closed in the early 90's after only a few years. I also had a classic 900 made in Arlov, not Trollhattan! The Trollhattan plant has made most Saabs including the classic 900 (with some production shifting away when the 9000 was built) and all Saabs now except the 9-7X and 9-3SS convertibles.Nickshu said:I thought Saab moved production BACK into Sweden?!? THe NG900 and OG9-3 were made in Finland and the Netherlands I think. The current 9-3 is assembled in Sweden, engines from Germany and transmissions from Japan, as far as I know. Is Saab moving back out of Sweden??
I think the relationship with GM has gone pretty well so far, for better or worse. The question is will GM continue to allow Saab some design-autonomy. THis is the key to Saab remaining a true Saab....not just another BMW 3-series that has the ignition key between the seats.
It has never been said any better.inyrmnd said:Simply put, once a SAAB owner, always SAAB at heart.
I believe that SAAB used to use German BOSCH engines. But I think the late models all have GM Ecotec engines. They're made at the Holdel plant in Australia. But everything is assembled in Sweden.Nickshu said:The current 9-3 is assembled in Sweden, engines from Germany and transmissions from Japan, as far as I know.
Yes, I think the GM Ecotec used in our cars is an GM/Opel adaptation, which is built in Germany.SAABRoma said:I believe that SAAB used to use German BOSCH engines. But I think the late models all have GM Ecotec engines. They're made at the Holdel plant in Australia. But everything is assembled in Sweden.
My sticker says engine (2.0T) produced in Germany. Transmission Sweden (6M).SAABRoma said:I believe that SAAB used to use German BOSCH engines. But I think the late models all have GM Ecotec engines. They're made at the Holdel plant in Australia. But everything is assembled in Sweden.
