1 - 2 of 2 Posts
how much coolant should i buy I have a shop that is gonna switch out the serpentine belt and thermostat. I am buying the part to give to him how much coolant should I give him.....
They should have coolant in stock...
But 1 gallon (mixed 50/50 makes two gallons) should be enough - to be safe, buy 2 gallons and you will have some left for top ups. That's assuming they actually drain the system at the bottom of the rad. If they just pull the thermostat and let the top end drain, then 1 gallon will be lots.
1 - 2 of 2 Posts
