1 - 7 of 7 Posts
According to the specifications i found, the difference between the turbo 9000 hatchback, and the 9000 S hatchback, a STOCK 9000 turbo is probably running 5-6 psi of boost. Is this correct? if not, what is the stock boost setting? Im not real sure about how these cars are set up, but i know on most turbo cars, you can just get a boost controller, and raise the boost level. Is this possible without the ECU swap? either way, whats the highest PSI that stock internals could SAFELY take? Thanks for your help.
hi and welcome to saab central, the 2.3 turbo runs 1 bar boost stock and in my experiance there doesnt seem to be a set level of boost before the ecu hits fuel cut so you will just have to fit you boost controller and play
I'm running 2 bar with external mods only on 203000 mile old motor making 340hp. However I reduced boost to 1.6 to drop the torque and give the front tyres abit of help in mantaining grip....from 447 to 401 lb.ft. ;)
Base boost is around 6.5 psi, this is the "safe" boost level the ECU reverts to if there is a problem in the system. Normal operating boost is 1 bar (about 14.7 psi). And Marrk is running 2 bars (30psi) :eek: , so the engine can take it but it would be advisable to use high boost levels for short periods of time, like the overboost feature in the 9-5.
1 - 7 of 7 Posts
