I got a pair of halogen headlamps for '02-'05 to compare with the HID. However I neglected to have cutter pliers and therefore didn't grab the connector and part of the wiring that goes to the headlamp.
As far as I can tell in WIS, the halogen headlamps should need only four wires: parking light, low beam bulb, high beam bulb, and common ground. However the connector diagram shows a bunch of other wires in the connector, but they don't show up in the wiring diagram.
The HID headlight wiring diagram is much more helpful.
Anyway, as far as I can tell, the basic wiring is the same for the HID and halogen lamps. On the headlight connector:
1: Common ground (1.5 mil wire)
2: High/main beam feed (1.5 mil wire)
3: Low/dipped beam feed (1.5 mil wire)
4: Parking light feed (0.5 mil wire)
I can understand why the HID lamps would have more wires in the connector (level sensor input, xenon warning light output, flash-to-pass function on halogen bulb [#7] ?? other stuffs) but there isn't that much in a halogen lamp.
