Here's my problem: I bought an early 04 2.0T Arc in 2007 with 33k miles. It has consistently dropped coolant level about a 1/4" per 3k miles. In 2008, the dealer did a pressure check and found no leaks, so I've lived with it. I now have 56k miles, and I finally decided to get a Blackstone analysis. It shows Potassium=100, Sodium=579, Antifreeze%=1.16 at only 4,274 miles on the oil. These values should only be 2, 18, and 0 respectively.
I have GM Protection Plan Major Guard which should cover a head gasket replacement. The Saab/Caddy dealership (I have to go to GM dealership because of GMPP) says they can't accept Blackstone report because it wasn't under their control. But even if I pay to have them do their own analysis in the future, they say those numbers wouldn't be enough proof of a head gasket problem because there are no other symptoms, and he doesn't think GM would approve gasket replacement. I say bull, those numbers can lead to bearing damage even though the Blackstone analysis shows no unusual wear (all other numbers were within normal ranges), and something should be done.
My question is, are there other ways for antifreeze to get into the oil on a manual shift car (block porosity problem)? What would you suggest I do, is there a way I can pressure GM? Maybe I should tell them I will be documenting this problem for a future lawsuit if my engine suffers early failure?
Thanks for your time, and yes, I've searched the forums, but didn't find quite what I was looking for.
