I know it's a vague question, but I've only owned manual Saabs. Lol.
I picked up a new to me '05 Arc 2.3T Auto on the cheap. Previous owner drove it to breakfast and then the car wouldn't start. Had it towed to reputable Saab shop to have the shift cable replaced. Now the car has a P0722 Output RPM No Signal. The tech says he swapped sensors and checked continuity and everything looked ok. I asked if he checked for short to ground or even scoped the sensor to see what signal it was giving and he looked at me with a blank stare.
So, I bought it and got it home. The battery was dead. Not slow crank dead, I mean DEAD. I haven't thrown an amp clamp on it yet but I'm assuming parasitic draw.
Here's my question. Isn't the output RPM on the trans reading the differential? I charged the battery, checked for codes and reset everything. Car started and idled for a while until I would assume it reached close loop and then it threw the P0722 code. I never shifted from park, just idled. So now it's in trans limp mode and shifting to reverse is brutal and its stuck in 4th in drive. What is the output sensor reading? Is it the speed of the diff while moving? I'm going to hope this is a wiring issue. I'll dig into it this weekend, I'm just wondering how these trans work.
