I guess I'll ask this question two ways:
I'm upgrading all speakers and installing a new 1500W amp (4x100W RMS at 4 Ohm). I thought I'd upgrade my speaker wires to 14 ga in the process. Dash and rear shelf are easy, but I'm getting stuck with the doors.
So, first I'll ask: how have others ran new wires to the door? If I understand my car's electrical harnesses correctly, the wires don't pass through the door, but connect via an electrical connector at the door (after the smurf tube). This is supposedly a bayonet connector (per WIS), but I must be pushing and twisting incorrectly because I cannot figure out how to get this thing off! But even if/when I do get it off, what then? There would still be no space for a new wire.
The second way I'll ask: is it even worth it? I'm guessing the OEM wire gauge is 18, yes? I haven't read an actual engineering explanation for using a larger wire gauge for lower power (i.e. not a competition setup) installs. Will I be fine with the existing wire?
Some notes on my setup: the amp I'm installing is a JBL GTR-104. It's got integrated Bluetooth, so I can run it without a head unit (I don't need/want/use radio, CDs, satellite; I just use my phone for all my music). So, I don't really need to use the existing audio wiring and harnesses. That's what got me down the rabbit hole of installing new speaker wiring in the first place!
