I have a 900 SE LPT. I've fitted lowering springs (35mm) and sports dampers. I'm on standard 15" wheels and wondered if there is an easy way do drop the car further. I'm looking for another 20mm ideally. I heard you could cut the springs????
Cheers ;)
if you cut the springs you're just doing a ghetto job, your alingment will be out of wack and it's just a waste of performance springs they're maid to be a certain height if they waren't why woud you buy them in the first place might be better off just cutting the stock springs, i think the only good thing you can do is to get lower tires if they're 205/60/15 just get 205/50/15 the only thing with this is that you're speedo will be off from 5km-10km
