1 - 8 of 8 Posts
I have a 2005 9-5 with four things that went out at the same time. The horn, the key alarm, the turn signal sound and the time /temperature display. The horn fuse #17 under the hood checked OK. Does anyone know what component would tie all of these together?
Checked fuses 5 , 16 and 17 and all are fine. Also noticed that the intermittent wiper function is gone and when you turn on ignition there's a faint squeaking noise out of the SID
I think but I'm not positive the clock spring in the steering wheel column is a common component.
The squeak could be your beaver.
There is a little speaker built into the display (the SID) which makes the turn signal sound. Sounds like the SID is gone bad
2005 9-5 Aero Wagon
Do your heated seats and windows also work when this is going on? Could also be your ignition switch.
Check fuses 8 and 27 in dash fuse box.
Sounds like the SID is toast, or possibly just disconnected. Was there anything done to the car just before this happened?
I would pop the SID out and see if the connector on the back is firmly attached.
1 - 8 of 8 Posts
