ok...shortly after warranty expired (yep, something always happens after warranty), the hood mechanism is not closing properly. When I release the hood, the spring mechanism doesn't appear to revert back. The last time, I was able to push the level forward, but the last time I opened the hood, I had to manually pull the level forward form the hood.
Suggestions on a fix?
Paul
Paul
Have you tried lubricating the mechanism?
Often though it's the cable that sticks - see this post:
http://www.saabcentral.com/forums/showpost.php?p=881961&postcount=5
Greasing the bonnet (hood) cable and latch mechanism is one of those preventative jobs I do every so often, as they can often sieze if left!
nope....I personally would not have even though of lubricating anything within the hood latch mechanism. I had a numerous cars in the past, older than the 9-3ss and nothing like this happened. I will give that a try, but will have to figure out how to get down there first..
Paul
