I've got SQR Stage IV software in my 1995 NG900, with all the supporting hardware.
I've reset my ECU multiple times in an effort to recalibrate it. I don't hit fuel cut if I get on it from a dead stop. i.e. I can run through the gears fine without hitting fuel cut (on a closed track of course); I hit 24psi and it settles around 20-21. But, if I downshift and floor it (pass somebody on a two lane road, downshift to 4th and floor it, etc), I'll immediately hit 25psi and fuel cut.
Base boost is set @ 7.5 PSI. I'm not really sure what else to check. As I've said, I've reset my ECU several times.
What else should I check?
clean out you bpc with some wd40 and compressed air...see if that helps, happens with some people...and that has helped
