1 - 20 of 22 Posts
Okay, so my drivers side highbeam wasn't working, replaced the bulb...still not working...
Then I looked at the fusebox at the "fusehole" for that highbeam had the wrong amperage fuse in there, the dealer I just got this 03 vert from must have put a 15 amp in there not a 10 amp like is supposed to be there, I changed the amp to be the correct one, and the light still didn't work, but that new 10 amp fuse didn't blow...I didn't check the bulb itself because it was too damn cold but I can't imagine that bulb would "blow" because of this.
Any ideas?
Check your owners manual, for a '96, the 15 amp is correct..Yours may vary.. I'd think 10 amp would work...There is a fuse for each beam and each light. Use your test light or multi-meter at the fuse panel to troubleshoot each circuit..
Good luck:cheesy:
hehe, it seems lots of ppl have the same niggling problems I'm slowly cleaning up on my car.
It's my passenger high beam that isn't working, I did the bulb change and fuse check, then found it starts working when I give that lights relay (orange one) a wiggle. It'd work for a while, then a few days later no go again.
I was getting close to pulling out the fuse box and checking the wiring under it, then pulling the relay apart and checking it, but that link certainly looks like I should open the relay first way to go, resoldering a couple of contacts looks nice and easy.
Thanks for that.
Andrew
Cool thanks for the help. If I just wanted to buy a new relay what would I be looking at? I am going to try that fix too but if the part is relatively cheap I may just go new.
OR
is this a universal part that I can get at an autoparts store, and if so, what exactly should I ask for?
Part Code: 4109070A
Part Name: Bulb Check Relay
Part Brand: KAE
Part Cost: $58.90
Part Description:
Bulb check relay for any 9000 94-98, 900 94-98, 9-3 99-03, 9-5 all.
Installation & Technical Notes:
KAE (Kaehler) made in Germany.
The German made PA6 Hella relay (Saab part no. 4109070) is Hella part no. 5KG005675-01.
Thanks man, I am going to fuss around with it for a while but it may just come down to buying that new part. Awesome, thanks!!!
My turning light didn't work and I THOUGHT it was relays fault. But after it came and I replaced the orange relay, my lights still didn't work. I checked the fuses again and again and... I found broken fuse. After replacing everything was fine.
My advice - check fuses again :) I bought my relay for 20 bucks on ebay. At the dealership it costs $150 :)
thanks for the advice man but I pulled every one of them and they were fine. I made sure they were seeded properly too. This car has an immaculate engine bay and everything 'appears'to be in good working order. I'll let you know what i find out.
The orange "relay" can be bypassed, temporarily, to test if everything else works. High and Low beams still have their own relays, and four fuses, two per side. The wiring diagram is in the Haynes manual and other places.
Discussion Starter · #11 ·
You guys think I should spend the money and get a new one...which is well over $100.00 or just buy a used one and see how long it works? I can get a used one shipped to me for like 35 max...
Simplest thing to do FIRST, is to be sure it is the relay. Borrow one from an independent shop, pop it in and see if the problem is cured. If so, you can very likely fix yours. I fixed seven for Tommy Turbo here in Columbus. I tested them before and after. All were easily repaired. I can do one in about ten minutes.
and really, you can get a soldering iron for around 10-15 and some solder for a couple of dollars more. Looking at that easy to follow photo guide you should be able to repair yours quite confidantly. It's really quite simple and once it's done the relay should be good for years.
Andrew
When I try to turn my high beams on both of them dont work. I checked the fuse and the relay seems to be fine. What else could it be?
Could be the switch, and could possibly be that the high beam filaments are shot in both bulbs. But unless you electrically tested the relay, you cannot rule it out yet.
Discussion Starter · #19 ·
Yeah Im gonna try to fix it first as I am pretty good with soldering...
You know its funny, if this part were 20 bucks or something I would buy a new one...but how in the hell they get 120 bucks for that little orange box is laughable...isnt an alternator like only twice that ...LOL
Warumono said:
I fixed it. I have to go buy some solder because I used the solder that was left there to make the bridge.
If it works, then you managed to make a good joint and it should be fine as is.
1 - 20 of 22 Posts
