1 - 10 of 10 Posts
Hey guys. The 03 electrical gremlins are at it again. Regardless of the setting, i can't keep my high beams "on." when i pull the handle, they go on, but only as long as the lever is pulled back. Any thoughts? I can't drive around holding the handle all the time.
In other news........its finally snowing here in southern ct, looking forward to some fun in the car.:p
FYI - unless your SAAB is built differently than mine, you pull the lever to you to "flash" your high beams; you push the lever away from you to actually put them on.
Well this might sound stupid, but I have the same symtpoms as the ones you mentioned when I have the actualy light switch control to position 2.
the reason you might having this problem is because u probably keep your switch on the off position and forget to turn it to the on position. that is the only way you can keep your highbeams on all the time.
If the center panel for the hvac, etc. isn't lighting up after dark and your high beams won't stay on as you say, then the headlight switch on the left side of the dash needs turned on.
All three positions have this same problem, that is the first thing i tried. Perhaps it is the relay, will check tomorrow.
i was having the same problem with m car on all positions but i just kept pulling the lever back and back and back again until it just started working.
like a spanish saying. "a las buenas o a las malas" meaning either your going to work or your going to work lol good luck on yours
thank you SO much!
THANK YOU!!!
1 - 10 of 10 Posts
