I have a 2006 Saab 9-5 estate, TDi. Recently it had a EGR vale and injector issue resulting in a lack of performance.
I cleaned the EGR valve and 3 of the injectors, number 4 just would not budge so I left it. The injectors 1 - 3 now have a nice spray pattern.
All pipes and electrical bits connected back now the car cranks but does not fire.
I removed the fuel feed to the injectors and checked the incoming fuel. Seems ok and plenty of pressure.. Still no luck in starting. The injector copper seals were all replaced apart from number 4 injector which was not removed.
Any ideas and suggestions will be gratefully accepted. I am in Cairnryan near Stranraer.
Thanks in advance
