My right rear door locks and window regulator are not working. The regulator works if you supply voltage to directly to regulator. I have also tested the large red and black wires feeding the door controller and I get no voltage. It seems to me that it is likely that it's either the main door controller of the controller in the right rear door.
I have checked the fuse, reset the battery and have had no success. I know the easiest approach is to connect a Tech II and have it identify the problem. However, the closest Tech II is over an hour drive and when I called them, they told me it would probably take them "a couple of days!" I refuse to give them a blank check.
Can anyone suggest a way to troubleshoot without the TechII analysis?
