1 - 17 of 17 Posts
Went scrounging around at a local wrecking yard and came back with a few nice items... One of them a pair of vent covers! Also a center for my steering wheel and a little DIN slot cubby holder.
Now to the question... I came a across a 3 door that had all the glass tinted. How do I remove the rear pop-out windows. I can find the 3 torx screws that mount the latch to the body. Im goin back tomorrow to yank them, is there any other mounting points? Or does anyone have any tips for removing them?
Thanks! Andrew
Or, simply break the rivets by pushing the window upward very fast. Once the trim covering the rivets is removed you can literally "tear"the window off.
or take a cordless drill with a (1/8?) inch bit. There are 3 rivets, then 2 brackets with some torx thingys, and the ones on the inside of course. I took mine off to tent them myself, that was a nightmare...endend up rolling the film back up and returning it. The "ultra highest quality" stuff was alreay scratched and wrinkled...
Alright... I was hoping I could just undo the torx on the latch and just pull the whole thing out w/o having to fool with the rivets. Pushing the window up 'very fast' scares me a bit. No worries, Ill see what happens tomorrow. Thanks for the info all!
nnamssorxela said:
I took mine off to tent them myself, that was a nightmare...endend up rolling the film back up and returning it. The "ultra highest quality" stuff was alreay scratched and wrinkled....
Haha. No way Im doing it myself. This is the most cost effective way of getting tinted glass right now.
yeah, I got really frusterated realllyy quick. if the window didnt have that black frame (or if you could take off the open-er lever, it would have been a piece od cake.
I suppose if you want to be a big sissy about it :cheesy: you could drill the rivets out, wich is the shure-fire way to do it , but you really can just tear the thing off without breaking the glass. I do it all the time.:cool:
Discussion Starter #8
I have a friend who does tint on the side... He says paitence is key. I guess that is why people will pay big money for it done right.
How did you re-mount the trim peice? Can you screw it back, or does it need to be riveted?
Discussion Starter #10
nnamssorxela said:
I suppose you could screw it in, but rivets would look original.
Well does the window still stay in without the trim peice? I cant picture whats under there. Thanks!
It's held in with a few puny rivets. That's why they are so easy to remove once the latch and the exterior trim is removed. With the trim and latch in place its nearly impossible to remove the glass without breaking it. But, if you have a key ,and can get the door open, you are only a few torx bolts and a few rivets away fom removing the window. The trim simply protects the "Achilies heel "of the rear window from would-be thieves when the car is locked.
Discussion Starter #13
Awesome-o!
nnamssorxela said:
here's some crappy night shots with a flash light .
Bad ***! Thanks man, its all clear now. Thanks!
no problemo! you can see the 3 rivet holes. And the shiny metal pieces will actually slide out of the black trim if it's lose, but you might as well leave it and just pop/drill/rip/stare off the rivets.
Moderator
Would you not get a 5-door? That way you get rear windows that wind down. Much easier... ;)
5 doors in these here parts are scarce as hen's teeth......:eek: Looking for a turbo, 5 speed version.....
1 - 17 of 17 Posts
