1 - 8 of 8 Posts
Hi
could someone please give me some advise on my problem.
I have a saab 93 2003 vector. the otehr day the remote 4 button key stopped working, i thought it was strange to just stop and had to open passenger door with the blade. The car starts ok and there is a error message saying "replace battery". I replaced the battery but the key fob is still not working?
Any ideas on this please, do i have to sync it back up or anything?
Thanks
Ian
If there is nothing wrong with the icm it should re sycn itselt when you go to start the car again.
I have another key which is quite damaged. The unlock button is missing, although this key does seem like its still works to lock or open boot
Hi
I finally have found the fault - i think...
One of the metal tabs on the key was bent and not touching the battery, i fixed this and was working ok, although after an hour left the battery seemed to lose its memory again. I entered car through passenger door and started and key seemed to aline again and work fine since... so not sure if its temperamental fault or if its sorted now.
I feel i should also mention the carpets got wet last week when we had a big downpour and the drain tube was blocked. could this be an issue?
the amp under the seat might have gotten wet... but that wouldn't effect the key.... take it apart and just make sure everything is seated properly.....
1 - 8 of 8 Posts
