Hi - Thought I could spot a B204 or B202 a mile off - Spotted this for sale locally and they can't find the engine number - all they know is that it's from a base model NG900.
Is this engine a B202 or B204? I think from the rocker cover B204 but then it has no DI and a distributor ....
Thanks for your help with this - Engine is to go in a 9000.
It will blow oil around driver's side of engine compartment if left open. If you don't mind applying some hillbilly engineering, and you can't find the exact plug, you can use a freeze plug. This will also work for B204. You'll need to measure the size of the hole.
B205R "Distributor Blanking Plug"
