2001 9-5........Problem, drivers side Heat vents blow cold air, while passenger and rear blow hot. Passenger side temp can be controlled, but Drivers side can not.Replaced the LH actuator motor and arm today, (Code8). problem persists and now code is 14. i didnt do anything on the passenger side. however i did notice while replacing the drivers side that the shaft on the motor was facing down and would not go in properly. I connected the wire and rotated it to the UP positon and installed the motor. not sure if this has anything to do with it. just bought the car and its great except for this and its cold out! Heat blows hot overall. just not drivers side.
Any help is appreciated.
