I drive a 03 9-3 2.0T
Nearly every time I put my Fob in it tells me steering wheel lock malfunction and won't let me turn the fob to start the car.
Things I have already tried:
Testing the battery, its only 2 years old, I had it tested and they said the battery was good.
Tested the alternator, it was good.
Changed out the ignition ( the part you put the FOB in ) and the wires. Still had the same problem.
Any ideas on what could be causing this problem?
If I take out and reinsert the FOB 3-4 times the warning goes away. Or if I disconnect the battery and hook it back up. It goes away,,, It's pretty annoying....
