1 - 2 of 2 Posts
hi can anyone help my 95 areo has big end problems now and will need a new engine or at least bottom end can anyone help and does it need to be
1. a turbo block as i think cause the 2.3 engine will be different
2. post 94 block as the gearbox input shaft changed or would i be able to fit earlier block and change the fly wheel and clutch
cheeers hope someone can help quick
yes you will need a 2.3 turbo block
and no you will not be able to use the early engine, completely differant
1 - 2 of 2 Posts
