Newbie to saabs here - bought a vector sport 150 tid on a 55 plate last month, and have got a couple of annoying questions...
1. How do you get the headlights out??
2. How do you get access to the front indicator bulbs easily and quickly?
3. I've an annoying noise coming from the bottom of the car as I drive down my road. It's been over my inspection pit, and I can't find anything loose, or worn..
4. How often should the EGR valve be cleaned, as my car has no pulling power below 1800 rpm until the turbo kicks in..
5. Even though I'm careful driving it, im still only getting 40mpg:evil::evil::eek:
What should I be getting out of this 1.9tid engine mpg wise??
He has a 1.9t and if he's out of the US mpg is a different value. But that depends if he's out of the US.
He has a 1.9 turbo diesel, and judging by the "55 plate" remark, he's from the UK, so 40mpg is ok, but not as good as a diesel should be. That said, it's a hell of a lot better then my diesel at 31mpg, but I do have a heavy foot.
As for the OPs original questions, I assume he's referring to physically removing the headlights as we don't have Tech II driving lights (headlights always on) over here.
Ho to clean EGR Valve 1.9 tid
nice info from Club Saab España by "fserrano"
how to clean the EGR Valve - SAAB 93 1.9 TiD 150 cv.
tools:
- flat screw driver.
- wrench 10mm.
- wrench 13mm.
wrench - Torx T25.
ÚTILES DE LIMPIEZA:
Agerul, KH7 or similar.
- Forza Horn.
- Scrubber aluminum.
- Cloth and plastic bucket
1. Saab 93 1.9 Tid 150 cv.
http://i42.tinypic.com/1214apd.jpg
2. cap engine.
http://i44.tinypic.com/1496qns.jpg
3. Valve Location.
http://i39.tinypic.com/2zre42r.jpg
4. EGR valve.
http://i44.tinypic.com/vease8.jpg
5. Hose clamp slacken. D-Flat
http://i44.tinypic.com/k4e4c1.jpg
6. Slightly loosen the two screws.
http://i42.tinypic.com/141jm6h.jpg
7. Remove the 4 screws to attach valve block motor. w10mm
http://i39.tinypic.com/nvz584.jpg
8. unplug connector.
http://i41.tinypic.com/23ie9mr.jpg
9. Presentation valve connections.
http://i44.tinypic.com/72u5x2.jpg
10. Remove the screws of the electric valve. Torx-25.
http://i43.tinypic.com/2lw2eec.jpg
11. Detail exhaust dirt board
http://i41.tinypic.com/im5gza.jpg
12. Soot inside valve.
http://i39.tinypic.com/f23tyt.jpg
13. Soot inside valve.
http://i44.tinypic.com/idytsw.jpg
14. cleaners tools .
http://i42.tinypic.com/1zsozs.jpg
15. Detailed dirt parts.
http://i44.tinypic.com/23kaed1.jpg
16. Forza acting.
http://i40.tinypic.com/vy5r34.jpg
17. cleaning process.
http://i39.tinypic.com/sbjv9e.jpg
http://i41.tinypic.com/28mex2.jpg
18. wow .
http://i41.tinypic.com/hun603.jpg
19.
Teton clean electric.
http://i39.tinypic.com/359iaf7.jpg
20. clean
http://i44.tinypic.com/nqvl15.jpg
21. valve Inner clean .
http://i44.tinypic.com/n4a0pv.jpg
22. Detalle chapita junta limpia.
http://i44.tinypic.com/21cw66f.jpg
I hope that will help,
regards,
fserrano
