Hi fellow saab owners :)
Firstly I must apologise for my first post as I'm asking for technical help.
I have seen a few threads on p0101 but as of yet I am not able to fix my problem so all help appreciated
I have a 2005 93 aero running a b207r with the 230hp hirsch, now it keeps flagging up p0101 air flow performance/range...
I have found NO air/vacuum leaks
I have fitted a NEW OEM Maf
And it still brings it up
90% of the time it drives ok but Occasionally kicks and then goes to limp mode, if I cycle the ignition limp mode goes and all is well but the CEL stays and I know it will happen again
Any info would be appreciated at a guess I'm going for wiring???
Discussion Starter · #2 ·
Right, I have disconnected the ecu and the car ran fine for a good 20 miles before limp mode and had to cycle the ignition, got the autolec coming around next week so will post what happen failing that ill see if there's any software updates for the ecu itself or the hirsch.
Will update when I know
cured
Hey all problem would appear to be solved!
Auto lec not needed sorted myself found a lot of pin holes in intercooler, I removed and water tested and found its about as air tight as a tea bag:roll:
Replaced it been on a 20 mile run and touch wood all is good
So hopefully this one man thread has helped some people.....thanks for the help guys lol :confused:
