Hi,
I have made a few changes to my fuel system, turbo and exhaust:
3" exhaust (no cat), 15T mitsubishi turbo, larger intercooler, bigger fuel pump, 3 bar fuel pressure regulator, fuel injectors (365), camshafts (all of these I have from my (slightly tweaked) 9000 Aero.
I have installed also an APC
The car is 1993 Saab 900 convertible (Lucas). The EPROM is 27C256.
Now the only problem is this EPROM. I have bought a fuel chip from a guy but when a friend of mine checked the bin file of my original fuel chip and the new one they were absolutely the same. So the seller of the chip told me that I already had a modified chip.
We have tried both chips but when the turbo charger is set at above 0,5 bar the car is not capable of handling it (i.e. there is not enough fuel).
So can someone send me a modified bin file? (then my friend will easily reprogram the chip - the goal is about 240 to 250 hp and about 350 - 380 nm.
Any other advice will also be welcome.
If I am not able to solve this, I guess I will have to go with the Megasquirt option.
Many thanks in Advance
