Bought a Viggen with a GT35 and recently snapped the neck on the oil feed line banjo fitting. I'm look to replace with a Steel braided oil feed line but I'm having difficulty figuring out the size of the 1. banjo fitting from the sump, the fitting/restrictor on the turbo (if any), and the length of line needed in the event I have to order a custom line. I've researched all over for specs and haven't found a good source to ensure I order the correct solution.
