· Registered
my wifes car will not start, last night after she got home from work, about a hour later try to start it and move it, she said it made the sound like when you try starting a car when its already running, so she turned it off right away, tryed again and wil not start, still wouldn't start this morning, , the car cranks over real good it just wouldnt take, any ideas what this could be, thanks
· Registered
same problem--solution
I have the same problem. When you turn the key to ON (right before you start the car) does the dashboard not light up? however, once the car starts, the dashboard lights up normally? if so it might be the ignition switch and the ignition cilinder. I had the same problem and the mechanic says that's what needs to be done. parts and labor will run you $450 or DIY for 220. good luck
