Hello, I'm stuck! I put in the key, lights come on and engine check completes but when i turn the key I hear a click and a low hummm but nothing happens. Lights dim, sometimes I get a traction control failure and/or steering lock failure when i then remove the key.
I've replaced the battery with a new one, checked the cables as much as i could see. The fuses look ok but to be honest I'm not sure what I would see if one was bad. I am hopping it's not the starter motor or alternator, how can I be sure which, can't afford any expensive fixes here.
