I have a 2001 9-3 convertible. Nice car with 84k miles. Major problem now is soft top won't fully close. Back 2 latches won't open, so there is a 2" gap. I'm hoping I can find a fix it solution on the site.
You need TECH2 to check what is your issue.
Have you checked hydraulic fluid level?
Thank you Mimmi.
The fluid is full and clean. Hopefully I can find a mechanic with a Tech 2.
Question: I looked at prior posts related to this problem and a 2015 reply said "Bend the tabs up a little for the microswitches by the torneau cover latches".
I'd like to try this possible fix. By chance, do you know where exactly the microswitches and tabs are located on the car?
Thanks.
Thank you Mimmi.
Thanks.
Microswitches are both sides of tonneau cover opening.
