Good morning all,
I have just joined the forum so hello to you all. Due to a Friday night purchase on ebay I now have 2 Saabs so I guess I am a bit of a fan... the 900 I bought has faults which I knew about but unfortunately the 9000 has just developed a fault which I would like some help on if possible?
Basically, on full accelaration the car goes up to full boost OK but when it gets there, it sort of 'flutters' - it looses a bit of boost and then it comes back again. It isnt violent, and at the moment it is intermittent but it is getting worse. The car is a 96 CDE FPT manual (quite rare I would imagine)
Any information or advice you might have would be greatly appreciated...
Thanks
Anthony.
I've had the exact same problem with mine. First I suspected a faulty APC Solenoid (all the hoses being OK) so I bought a new one and it made the things better... but didn't solve the problem completely. Turned out it was the DI-cassette that was dying and couldn't deliver enough juice at high-boost. Try fitting a working DI on your engine, if you can get your hands on one, and see if it fixes your problem.
Thanks for that - I believe the DI was changed for a new one less than 2 years ago, so I may start with the APC solenoid first. Is this a service item from SAAB or is it a 'breakers' item?
Cheers,
Anthony
the plot thickens
In addition to the above problems, when I come off throttle (after being on full boost), in addition of just the normal quiet whoosh from the DV, I am getting a fluttering sound and also what can only be described as a ghostly sound... v strange. Whilst the fluttering sounds very 'rally car cool', I suspect that it isnt particularly good news. Does this still point to the APC solenoid?
Thanks,
Anthony
Sounds to me like the fluctuation in boost is quite usual in fpt 9000's.
I have a 93' 9000 Aero and mine does the same exact thing.
Don't exactly know the problem, but it maybe a weak wastegate spring.
I had the same "sneeze" happen to me yesterday.
But I was only getting base boost because a hose was broken.
...Weird 9000 problems...
