Hi, any way to remove the pipes going to the heater matrix?
Mine are broken and been poorly "fixed" by previous owners. Have an opportunity to change the pipes from a donor car.
2000 year 9-5, v6 turbo
269824
Cheers mates
I had a bad coolant leak and used water to try to figure it out, some got left in the system over the winter and the pipes broke. I cut the broken sections out and replaced with radiator hoses because removing the piping seemed likea ton of work. Where are your leaks located?
Someone has literally done the same thing as you on your pipes, and its leaking from it now. Trying to get a new one that i dont have to patch up
