Hey all.
Got a quickie here. I'm reassembling my engine and i'm going to be bypassing the heater core. I wonder if i can just cap off the water outlet side, and also plug the return line side on the water pump, or do i need keep the flow going between the two?
TIA
-=tristan=-
Discussion Starter #2
anybody?
-=tristan=-
It will work either way. But it is simpler to run a hose from the heater tube connection from behind the engine to the heater hose connection on the block to keep the coolant circulating. Where do you find a plug?
