The eeuro site where you find the repair kit has an installation document that has a lot of photos of the heater box taken out of the car so that you can see what is going on inside.
I have looked at that document many times. My problem is I can't tell which part is the blend door and which way it rotates. My guess is that the moving door is the part that I have highlighted below.The eeuro site where you find the repair kit has an installation document that has a lot of photos of the heater box taken out of the car so that you can see what is going on inside.
Ditto...Well, the kit did the job, but I must say it was one of the more painful experiences I have had in 30+ years of working on cars. One really needs to be a contortionist.
It's often the resistor on the recirculation motor circuit board, which isn't too hard to change. Mine was blown, changed it fairly easily, then it blew again, changed it, blew again, gave up. There must be another problem causing mine to burn out, changing the resistor has worked for others.Still have the ACC 19 error, which I understand to be the recirculation flap. I am hoping it is stuck in the open position, since I never use the recirc function anyway.
