1 - 11 of 11 Posts
anyone know the dimensions they used for their heat shield, or the dimensions of the BSR heat shield.
I'm trying to make one and it would be a lot easier if someone already had the specs
.. which heat shield are you talking about, there are several on the car. I might be able to pull some dimensions if I know which one.
Having BSR Stage 3 (Arc/Aero) installed, I can say that none of the hardware BSR supplied had a heatshield.
yes! you know? the metal plate who replace the plastic box ok the air filter?.BSR supply a plate with hole for plastic pipe on cone air and...
Ahh sorry, I forgot about the air intake. ;oops: One should be able to measure simply using cardboard as a template, no?
thanks alot. already got my pipe bent but i dont want to do anything until i get the heatshield ready
can you scan it in, or photoshop it together? or not just post the measurements. Ill try to figure it out heh :)
Here's the best I could do with graphics. If you need any more detailed dimensions. There are lots of cutouts, so I couldn't include them all, but this should give you a good start. If you want actual pictures let me know.
1 - 11 of 11 Posts
