Recently as the cold weather has started to come upon us i have noticed that my heat in my 2002 9-5 Linear has not been working correctly. I have tried to find fault codes with no results. I had the bypass vavle replaced a few months ago as it was leaking coolant. After reading all the forums on this subject i have tried to purge the cooling system of air by following the procedure of allowing the car to warm up with the resevoir cap off and squeezing all the hoses that i could get to to allow air to pass. The part of my problem that is unique is that when i accelerate quickly and spool the turbo the heat works very well and as soon as cruising speed is reached the heat fails and blows cold air. I know there is a vaccum aspect to the bypass valve but i am not sure what the entails. The turbo also doesnt seem to spool as well as it used to and i have to downshift more to get the turbo to spool where it would have done so without a downshift before.
Can these two things be related??? any ideas would be greatly appreciated.
