The head rests on my 94 cab (The last of the classics) do not stay up. They ratchet up but if you put your head back they just go down again. Any idea what is wrong? I have searched and found alot on how to remove the headrest but nothing on the ratchet.
Weird. It is likely too loose.
How do you remove it btw?
According to what I found using the search, To remove the head rest, you unzip the back of the seat and roll it up. then there is a torx scew that needs to be removed. It must act as some type of stop. I guess I will open it up and see what it looks like. This is the only problem with the car, so I feel like I should do something.
