1 - 2 of 2 Posts
1997 900se 2.0 turbo . when I select the far right headlight position my headlights go out along with the dash lights. I checked all the relays and fuses . I have also re soldered the orange relay and I still can’t get the lights to work I changed out the headlight switch too and I get the same result. I could use some advise as where to go from here.
I was reading about your problem and came across something interesting....Depending upon the market ie EUR, Canada ect.. you can program the DICE to do different things in each position. Now I know it should turn your headlights on too but maybe you need to bring it to a dealer and reprogram the DICE using the TECH 2. Because it sounds as though you covered all the bases. That would be my next step.
1 - 2 of 2 Posts
