A few days ago I started noticing that my HLs were always in high beam mode. It turns out that they somehow started defaulting to high beam when I turn knob from OFF to PARKING to HL. I have my DRL fuse pulled years ago. But I can flick stalk to bring them back to low beam, but if I turn everything off and back on, they go back to high beam again. All bulbs are working, by the way.
Any guesses ?
PS: high beam indicator in dash panel has always come on erratically since day 1
Thanks.
check the headlight relay under the hood... should have a clear top on the box... the particular relay if i remember correctly is the biggest one (takes up two spots, and is orange... ) you probably need a new one, but try wigglin it and seeing if that does anything
