1 - 9 of 9 Posts
Passenger light went out.Bulb is good and connections are good.I also checked the fuses for the headlights and daytime running lights,alls good.Anyone have this issue before?
Check the orange relay (fuse box) under the hood; wiggle it and see if the light comes on.
Resoldering is REALLY simple if you have (or have a friend who has) a soldering iron. Take the cover off, heat the solder until it melts, move onto the next pin.
A half-hour job at most.
They seem to turn on but fire an error on the dash. I rarely use them as is so its just a minor annoyance at this point.
Easy fix.Checked fuses in panel under hood and R low beam 15amp fuse was blown.All good now! Ty everyone..
1 - 9 of 9 Posts
