I assume you got Osram D1S bulbs. Assuming they are genuine (always a gamble from eBay), they would be the correct bulbs.
Is there a yellow warning light lit on the dashboard, kind of like a headlight with an exclamation mark in it? (In fact, that's what it is supposed to be.)
How is it getting brighter and dimmer? If you park the car a short distance from a wall, does the entire output from the LH headlight become more intense and the fade, or what?
If you are ambitious (you have already pulled the bumper once!) you can swap the ballasts across the car and see if the issue moves with the ballast or stays with the headlamp/bulb. If it stays, then you can swap the bulbs across. Maybe the Osram is no good (and maybe not genuine?)
It really is unusual for a discharge bulb to brighten and dim. They are either on or they are off. I'm not sure what is happening here. Maybe some of your answers above will give a clue.
The ballast unit is shared with the 2002-2005 9-5s with HID, and I expect with the newer 9-5 right through 2009.
A used ballast could be installed. Nothing horrible should happen.
Keep in mind that a Tech II tool is highly desirable to properly set things up. The headlight should work with any old used or new ballast dropped in, but ideally the system should be calibrated. And of course the ballast programmed to be the correct side of the car.
