1 - 7 of 7 Posts
So for a while I've noticed at night my headlights tend to flicker. It's apparent when idling and when backing up I can also see a flicker in reverse lights. If I turn the car off but leave the headlights on the flicker goes away. I just put a new battery in today as the old one failed testing (12.43v, 399cca).
Could this be the sign of a failing alternator and/or voltage regulator? Any way to test it to be sure? I did measure voltage at the battery with the car running and I got 14.6v at idle and about 14.7v at 1500 RPM.
2004 Saab 9-3 Linear
Is there anything else being switched on or off?
If you have halogen headlights, they shouldn't flicker--the UEC is supposed to maintain 13.5V through PWM (according to WIS). I don't know if the REC does anything similar for backup lights.
What's the frequency and duration of the flickering?
In short, it shouldn't do that. And 14.7 V sounds quite high, assuming the voltmeter is accurate. It's not doing your battery any favours if it's always at that voltage.
Headlights are halogen and both assemblies were replaced last year. The flickering is almost constant, turning the air and radio off seems to have no effect.
Weird. Those are good voltage numbers. Still, could be intermittent in the alternator. Does the voltage bounce when idling and it flickers?
1 - 7 of 7 Posts
